04-15-2024
01:27 PM
04-16-2024
12:34 AM
computergeek541
04-15-2024 02:13 PM
You can use WhatsApp or TextNow app for free calling and texting through wifi or purchase a local SIM in Iceland.
04-15-2024 02:01 PM - edited 04-15-2024 02:02 PM
@Buck72 , a little off topic, there are better deals at the moment. IIRC your plan is $102 for 90 days. The same $34/30 day payment will get you 50GB which is effectively 150GB over 90 days.
04-15-2024 01:29 PM
NO service outside of USA/Canada.
04-15-2024 01:28 PM
HI @Buck72
sorry, your plan won't work in Iceland and there is no add-on that can make it work. PM only has roaming service in US
So, just buy travel esim if your phone support, or buy local data sim card
