Traveling
hcousins
Hi,
I am traveling to Europe end of May into June. What does PM have to offer re calling from Europe?
thanks
DDM69
@hcousins
FYI...the search bar above will easily help with issues such as this.  Enjoy your trip! 😊
hi @hcousins if your phone supports eSIM, consider buying eSIM , easy and quick.  I can provide you more details
@hcousins
Unfortunately, there are no roaming plans in Europe from PM.
If your friends and family have WhatsApp,  you can get for free WiFi calling and texting using your existing cell number.
Or use TextNow but you need to pick a secondary number on WiFi for free calling and texting.
Final option is to buy a local SIM.
Lieux
@hcousins You can have a look at Lycamobile or free. They’re offering very good deals for local plans.
@hcousins
Sorry, PM does not have any service in Europe
So, your only option is to get local data sim card for data.
For voice calls and text, you can download VoIP app like TextNow, it will work as long as you have Wifi or mobile data
Please remember, if you need 2FA code while you in Europe, like from banks, make sure you arrange to receive via email or Authenticator app before your trip
More important thing to remember, Enjoy your trip
