Traveling in the US
Nikkirenn1
My plan is  unlimiited canada-us minutes and 40g data. Will i still get roaming charges??
DennyCrane
Sounds like you're on the $50/40GB Can/US plan. As @dabr mentioned, you should switch to one of the new plans for as low as $34 for 50GB of Can/US data. Hurry though, as the offer expires May 4th.
dabr
@Nikkirenn1   Not sure what plan (with US roaming) you currently have but PM has an incredible deal for 50GB data (5G) for $34 which also includes unlimited calling/texting that can be used on either side of the border, however, a heads up that it's only available until March 4th, if you're interested.
Strawberryface
No need for roaming charges or such if you have a plan that contains US.
@Nikkirenn1 no more roaming add-on needed for IS travel.  Just turn on mobile data roaming on your phone Me connect to either T-Mobile or AT&T and you will be using the service like you are in Canada
