Lte
03-01-2024 01:26 PM
03-01-2024 03:28 PM
You are right, after I move to other place(downtown Toronto),show 5G ,it was show LTE at east York some area.thanks
03-01-2024 02:53 PM
There are some areas where some networks just can't provide you the 5G. You basically have to get around to an area and your phone should automatically go back to 5G.
03-01-2024 01:42 PM
If there is a 5G in your phone settings. Just enable it. You can conduct a speed test to confirm that it is 5G since there are phones that doesn’t show 5G.
03-01-2024 01:41 PM
If you provide a phone make, model, and year it came out, for a better answer?
My phone can't access 5G even though I upgraded on a promo on it. It gives me my old option of 3G or LTE. It's switched on LTE (until I upgrade my phone I think).
03-01-2024 01:30 PM
@Way1 Some phone even thou 5G capable like the Samsung s20 army supported with 5G network on PM what phone do you have ? And have you tried to change the network in phone settings ? Also note even with phone set to LTE being in5G plan should still see better speeds of 100MBS 4G plan
