03-01-2024
01:06 PM
03-01-2024
07:28 PM
computergeek541
Why all of a sudden am I getting ads every time I open my texting app to either send or recieve a text
03-01-2024 03:41 PM
Thank you. I am trying that now. 🤞
03-01-2024 01:47 PM
03-01-2024 01:13 PM
Hello Publick Mobile service does not have ads if using your normal built in texting app.
If your using textnow, whatsapp ect then thats those apps proving ads to you.
03-01-2024 01:10 PM
@Bucca PM does not have the texting app, you actually using the app on your phone to receive the sma, and you probably using some 3rd party texting app and not the stock one
Confirm the name is the apo and uninstall it and go back to default texting app. If you are using Android , use the Google one. Download Google Message and set it as default one, no ad for that
03-01-2024 01:08 PM - edited 03-01-2024 01:08 PM
@Bucca , what texting app are you using? Any ads on the phone apps have nothing to do with this service.
03-01-2024 01:07 PM
Public Mobile doesn't have ads. You're probably talking about a 3rd party app? Like TextNow or something?
