03-01-2024
12:55 PM
03-01-2024
04:10 PM
computergeek541
How do I actually speak to someone when trying to activate a new line and its failing?
03-01-2024 03:49 PM
Still waiting for someone from support to resolve this. I don't understand how they can provide support like this if you can't even get activated and you're already paying?
03-01-2024 01:04 PM - edited 03-01-2024 01:05 PM
@flash67 You send it right from here as your already logged into the community tap that message bubble bottom of the screen to the right or use the direct link I or one of the other members sent you
03-01-2024 01:02 PM
If you cant even login to your account because its stuck at trying to activate, how do you send a message from that account you're having a problem with?
03-01-2024 12:59 PM
@flash67 To contact support use the message bubble bottom right of screen
if that doesn’t work you can use this private message link also
send a private message To CS_Agents
03-01-2024 12:58 PM
Physical SIM
03-01-2024 12:57 PM
@flash67 are you activat8ng physical sim or eSIM??
if eSIM, it could be and issue with eSIM setup on your phone
But try this first
if that does not work, open ticket with PM support:
03-01-2024 12:57 PM
@flash67 There is no one to actually speak to. All service is done online. Customer service can be messaged at the link below.
