Trasfer to public mobile
Lovedeepm1
Hey I’m with fido right now , wanted to transfer to Public mobile ,
im getting 35 dollar plan with fido for 15 gb
Is there any same kind of deal available?
7 REPLIES 7
adding to what @will13am  mentioned about rewards there also a promo for 50FF12MTH for plans $40 and a above
$5 off for 12 months and with the rewards points of $6 in points for the first year that would bring you to $30 for the exact same plan for the first year …. And if you happen to refer some friends and family on that first year you will be able to save even more
dabr
@Lovedeepm1   Adding to what @will13am has said, you can also use promo code 50FF12MTH which is supposed to give $5 discount for new activations on plans of $40+ according to an email I received from PM a few days ago.  edit:  adding discount is for 12 months.
PM also gives you 5% back in Points rewards for paying your bill or buying add-ons that can be redeemed after accumulating 15 points ($15) to be used towards a future account renewal or purchasing add-ons.
I would add the Fido deal is short term whereas the Public Mobile deal is permanent.  With rewards considered, the price gap closes and could swing the other way depending on referrals.
@Lovedeepm1
Good deal, it must be a Black Friday deal. I suggest you stay with the Fido plan.
HALIMACS
@Lovedeepm1
My advice:
  1. Stay with Fido with that deal.   Nothing with Public Mobile matches that currently.
  2. Purchase a Public Mobile SIM card.
  3. Check out the Announcement section every 2-3 weeks for special offerings, then when one comes up that is worth the switch, go for it.  When you do, have a current customers referral code ready to enter upon the activation screen.
https://productioncommunity.publicmobile.ca/t5/Announcements/bd-p/Announcements
DennyCrane
What's your motivation to switch if you haven't found a new plan yet? 15GB with Public Mobile is currently on promo for $40 per 30 days. Regular price is $60.
@Lovedeepm1  There’s plan for $15 GB for $ 40
