09-18-2022 03:51 PM
Hi,
I am trying to transfer my phone number to another provider. I received the text message requesting to authorize the transfer. Replied yes within the allowed timeframe.
Then got message from the new provider telling me the transfer could not be processed due to wrong IMEI (copy pasted it, triple checked multiple time. And then tried with account number, same error message from new provider.
The new provider is suggesting PM might have the wrong IMEI in file, but I'd really like someone from PM looking into my request for transferring.
09-19-2022 08:45 AM
It was at the time, but the problem has been resolved. Thank you
09-18-2022 08:47 PM
Well since we're back after 4 1/2 hours... @aminie - is your account here actually active? Porting requires the account to be active.
09-18-2022 08:46 PM
@aminie wrote:I had the option of either providing IMEI or PM account number. Tried both ways, both failed.
Is your account with Public Mobile currently ACTIVE @aminie ? It needs to be active to port out to another provider (To Telus or Koodo, perhaps the exception).
If you Public account is suspended you need to make a manual payment to reactivate it, then you can port out.
What are the reasons the new provider is saying the port is failing?
09-18-2022 04:13 PM
09-18-2022 04:11 PM
I tried both, and neither worked. Just submitted a ticket, thank you
09-18-2022 04:10 PM
Unfortunately typing did not work either.
09-18-2022 04:01 PM
The new provider should care of the all porting details, but if info. was provided to them that was incorrect than they cannot complete the port. Do they require the IMEI, for some reason, or is this just the method you choose to port?
Can you provide Public Mobile's account number to the new provider instead? This can be found under the PROFILE tab in your My Account. Or, if you received an email activation with public mobile then it would be in the TO line of that email @aminie
09-18-2022 04:00 PM
You can also try your four digit account pin number? But with the way glitches are nowadays maybe all the recent renewal glitches is affecting something in your self-serve account?
You can contact customer support to confirm your account number and your IMEI number and verbally or technically in writing approve the next incoming port request from your new provider.
09-18-2022 03:59 PM
When porting, just use the phone number, account number with account holder name. Using IME may cause issues. You could contact customer service agent.
Submit a ticket for CSA help.
https://www.publicmobile.ca/en/on/chatbot
Type: I need to port out.
Follow the prompts to submit ticket.
CSA may ask a few questions to verify account ownership and then should be able to help you. Response times can take a few hours. Check your private message inbox (envelope in upper right corner of website).
09-18-2022 03:56 PM
@aminie , you could initiate a support ticket using the chatbot link to confirm the IMEI on your account. The account number should work. Try typing the number. Pasting might include hidden stuff.
