Transferring number to new sim card
gurdialgill49
Hi group,
Need help please. My old sim card stopped working on my phone. There is damage done on it which is why phone won't register. I bought a new sim and need to transfer old number to new sim. What is the process in doing so?
@gurdialgill49 wrote:
Hi group,
@gurdialgill49  -
See "How To Change Your SIM Card" at the bottom of this Help Article: https://www.publicmobile.ca/en/on/get-help/articles/sim-swap-fraud
JL9
Is the damage to the sim card, to the phone and both. Test both the card and the phone if you have another one you can put your sim in and another sim to see if the phone works with no issue. If it is the sim the steps laid out for changing sim in self serve will get the job done for you
darlicious
@gurdialgill49
You will have to use the email option for 2FA. Then enter the verification code and confirm and the swap is done. Insert the new SIM card in your phone and reboot.
If you cannot access the email for 2FA then your only other option is thru customer support to swap dim cards.
To pre-verify your account include in your private messaging only your full name, address, email, phone # and 4 digit acct pin #.
Spudster
First,  try old SIM in another device.
Then,  if needs replacing,  use the email verification method to do the change SIM in self-serve
hairbag1
Log in to your account / My Profile / Change Sim Card.
