03-22-2024
12:20 PM
03-22-2024
10:40 PM
computergeek541
Hello, I am transferring my number from Bell to Public Mobile. I want to keep my current number. My bell line/number is currently active with the sim in my phone.
When signing up for Public, do I order a new sim? Or after paying, do I request to transfer my number and the existing sim in my phone updates to public mobile?
I am unclear whether I just keep my existing sim and it updates my number to public after I order, or I have to wait for a new sim from public. Thank you.
03-22-2024 12:32 PM
thanks so much everyone. I am saving so much money ❤️
03-22-2024 12:29 PM
And after you transfer your number from bell to PM, your bell sim is useless and can't be reused if you want to go back to bell.
03-22-2024 12:28 PM
To have a service with PM you HAVE to purchase PM SIM.
Then you initiate porting from Bell - keep Bell SIM in your phone, reply yes to an authorization SMS. After that put PM SIM into phone and it should work.
Bell SIM will stop working and most likely will not be able to be reused.
03-22-2024 12:25 PM
bell sim is for bell only. You need a PM sim.
03-22-2024 12:25 PM - edited 03-22-2024 12:26 PM
@iuhsDIUwhe - You order your SIM card, when it arrives, you can continue to the port.
Step 6 is porting from Bell. Step 5 is choosing between eSIM or ordering / entering in the Physical SIM card.
You will have to wait for the SIM card to arrive to port from Bell to Public Mobile. Your Bell SIM card will continue to work till you start the porting process.
I would suggest to not use the IMEI, but the Account number from Bell.
If you want the SIM card ASAP, go to any Mobile Klinik or Telus / Koodo store to buy one for $10. On Amazon it is $5.
If you go in store to buy one contact CS_Agent after activating for a refund of $10 because it is free online and in store if you contact CS_Agent.
⬇️Click the link for an Agent * ⬇️
If the link above doesn’t work, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for an agent because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
