06-02-2020 05:21 PM - edited 01-05-2022 11:00 AM
I transferred my number and it works for calling but not texting. I also don't get incoming calls and texts directly to my iPhone, just through the Nextplus app.
It's been more than a day and a half so far since transferring.
I tried deleting the app but it didn't work.
Can I fix this?
06-02-2020 05:39 PM
I'm waiting for a response to an email I sent them. Thanks.
06-02-2020 05:32 PM - edited 06-02-2020 05:40 PM
@morganja95 wrote:I transferred my number and it works for calling but not texting. I also don't get incoming calls and texts directly to my iPhone, just through the Nextplus app.
Can I fix this?
@morganja95 You will only be able to receive calls when and if Nextplus release the number to Public Mobile. Did you check with them to make sure porting out is allowed?
06-02-2020 05:26 PM
@morganja95 your port is probably stuck. Contact a moderator and explain your situation. There are 2 ways to contact the Moderator Team:
Keep an eye on the envelope top right of your screen. The mods answer will show up there. Stay safe.
Welcome to PM .
06-02-2020 05:24 PM - edited 06-02-2020 05:25 PM
@morganja95 hi it can take up to a week to complete do not close your account
