Huawei mate 10 pro
Marcellin375
Hello all,
Do you know if the Huawei Mate 10 pro is good with the abonnement or not ?
Thanks for your return.
Staliger
@Marcellin375 Yes, great choice, and it will work with PM. Go for it!
gblackma
According to https://apn-canada.gishan.net/en/apn/public-mobile/huawei-mate-10 its 100% compatible has all the required  3g and 4g  LTE bands. Make sure its unlocked amd do not camcel your previous providers account if porting. Welcome to PM. Stay safe.
Here's 4 articles on activation and porting and the Refer a friend reward  if you need them:
1. What you require to activate https://www.publicmobile.ca/en/bc/get-help/articles/what-you-need-to-activate
2.How to activate https://www.publicmobile.ca/en/bc/get-help/articles/activation-account-set-up
3.How to port https://www.publicmobile.ca/en/bc/get-help/articles/choose-your-phone-number
4. Refer a friend https://www.publicmobile.ca/en/on/get-help/articles/the-refer-a-friend-reward
kselmak
Should be fine
geopublic
@Marcellin375 wrote:
Hello all,
@Marcellin375  Yes, it will work without any issues.
It supports both 3G bands B2 and B5 and also supports LTE: B2, B4, B5, B7, B12 and B17 so you are good!!
