03-13-2026
06:36 AM
03-13-2026
02:03 PM
computergeek541
Hey guys!
So 3G is shutting down soon out here in Manitoba (even though I live in Saskatchewan), and my Huawei doesn't have the option in settings to toggle to volte network... I read that it's because carriers choose to only use certain phones but is there a way to make the P30 pro still connect?
Thanks in advance guys!
03-13-2026 11:53 AM - edited 03-13-2026 11:54 AM
I agree it is a temporary fix but if the OP can’t afford or other reasons to purchase a new phone. It will work for now until they afford a new phone.
Just giving a suggestion.
03-13-2026 10:05 AM
Using VoIP app (A2A) is not a long term solution for those phones without VoLTE support. It is at max be a short term fallback before OP gets a new compatible phone
03-13-2026 07:54 AM
Sorry @Querc
if your phone is not on PM's VoLTE whitelist, which is like your phone, there is no workaround with that. You will get shop for a new phone
