03-13-2026 09:59 AM
I'm trying to transfer my public Mobile number to another carrier and that carrier has been unable to do so to date. They have also told me that I need to have the port protection removed, how do I do that?
03-13-2026 11:49 AM
Your new carrier will need to contact PM again to have the confirmation text sent to your phone again.
03-13-2026 11:05 AM
I have been waiting for the text auth message to approve the change and the other carrier says that the request is hung up in their system. They asked me to inquire about port protection.
03-13-2026 10:28 AM
hi @sobrien
PM does not have port protection setup. All it has is the text authorization , which will send to your Active PM account via SMS. did you get that?
and if your new carrier says it has trouble porting, tell them there is not port protection and ask them the specific error they see. Also, confirm if you have given them the correct PM account number
or you can ask PM support agent and see if they ever receive the port request
submit a ticket with CS Agent using Chatbot here:
Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
(If unable to receive 2FA SMS, click "Didn't Receive Code" or "Resend Code" and Select "Send Email")
If any issue with ticket submission, you can submit ticket by direct message:
03-13-2026 10:02 AM - edited 03-13-2026 10:12 AM
PM doesn’t have port protection as an option. The only requirement is to keep your active and reply to the confirmation text with YES with the PM SIM in your phone.
