04-03-2023
03:44 PM
04-03-2023
03:47 PM
computergeek541
I received an text stating that an attempt to transfer my current phone number has failed. I did transfer the number when I signed up 5 weeks ago. WHAT IS GOING ON!!!! If I lost my number this will be the last straw.
04-03-2023 04:36 PM
Check your previous provider's account and ensure the service is active. If it's prepaid you will need to make a payment to resume service. If it's postpaid you are likely still being charged for service. You can only port in from an active service. The exception to this rule is if your previous provider is telus or koodo. Contact customer support to help you with your port request if this is the case.
Once you ensure you can port in you can initiate this as per the instructions supplied by @softech earlier in this thread. If you no longer have the old Sim card to reply YES to the PAT (porting authorization text) within 90 minutes of receiving it you will need to contact your old provider immediately after you submit your port request to verify and verbally authorize your port request.
04-03-2023 04:34 PM - edited 04-03-2023 04:37 PM
@Jrmorris wrote:I received an text stating that an attempt to transfer my current phone number has failed. I did transfer the number when I signed up 5 weeks ago. WHAT IS GOING ON!!!! If I lost my number this will be the last straw.
@Jrmorris , if you ported your phone number to Public Mobile 5 weeks ago did you leave your old providers SIM card in your phone to reply YES within 90 minutes to the text confirming you wanted to port your number in? If yes, after you put the Public Mobiles SIM card in your phone did you check that your phone number ported successfully? Does that phone number show up on caller ID when you call people? If yes, that would close your account with your previous provider.
I’m trying not to read between the lines & figure out what happened & what process you went through to port your phone number over to Public Mobile.
Edit: It shouldn’t have taken 5 weeks to find out that porting your phone number in failed! You would notice on caller ID & your account that your phone number didn’t port in & a different phone number would show up!
04-03-2023 04:15 PM
In my experience with PM - following 3 months of suspension, accounts are de-activated and numbers lost. Several years ago I made the mistake of letting my Bell service lapse and tried to port my number to PM but obviously that didn't work. Was at that time told that I lost my number because I let the account lapse.
04-03-2023 04:04 PM
HI @Tsawwassen if it is just a month, the number will still be there. Carriers have to keep the number for as least 8 weeks before releasing it again
and if it was a postpaid account, carrier and resume the service (maybe a sim card cost). And since it is a postpaid, basically people only need to pay for couple days the service was resumed for porting. Postpaid will only charge you the days you used and refund the rest
04-03-2023 04:00 PM
@Tsawwassen wrote:I hope that your old number was still active and paid for before you started the porting - if not you lost your old number that is lost for-ever. Common mistake made by many - Now what's done is done so just register and select a new number --- Good luck.
A phone number being inactive doesn't necessarily mean that the number has been lost forever. In the case of a prepaid account, sevice can be resumed within the conditions of service for that carrier by making a payment. Also, a cancelled postpaid account/phone number can also have service resumed within a specific amount of time by contacting that carrier.
04-03-2023 03:51 PM - edited 04-03-2023 03:52 PM
04-03-2023 03:49 PM
Bear in mind, @Jrmorris , that in order for porting to successfully occur, the prior service account must be active and you must respond “yes” to the port authorization text with the old Sim card in your device.
Then you replace with your new Sim card, reboot your device, and everything should be good to go.
You should be able to also do this change number function in your self-serve. You can either use that option or the phone number I sent you to your private message box.
04-03-2023 03:49 PM
@Jrmorris Your old provider would have already sent you a text and you need to reply YES within 90 mins for the porting to complete.
Look like you missed it. It has been a full month and the porting request has to be cancelled
is the old account still active? call them and find out. i
If it is active, you can re-submit a porting request from My Account, using change phone number. But this time, you need to have your old sim card in a phone, and reply YES within 90 mins for the porting to go through
https://selfserve.publicmobile.ca/en/account/edit/your-account
04-03-2023 03:46 PM
I will private message you the number to help with porting.
Hopefully you can use someone else's phone to call this number.
To check your private messages, look at the envelope icon between your avatar and the bell icon on the upper right.
