Transfer Sim card
Jeannine_Ander1
I cancel my subscription to my $20 account. I want to activate my $15 plan with the same Sim card. However, it keeps telling me that the SIM card is already in use. How do I transfer the SIM card to the $15 subscription?
HI @Jeannine_Ander1
to save the sim card cost, you can use the esim on your phone to activate if your phone has the feature
or you can buy a PM sim card from Amazon for only $5
https://www.amazon.ca/Public-prepaid-postpaid-Activate-Allinone/dp/B06X9ZGDWG
then when you activate, added a friend code (on the payment step) and save $10 one time
..and not a lot of time, you can also add a promo code  AMZ4T2X7W  to save 40% of your first month
https://productioncommunity.publicmobile.ca/t5/Get-Support/September-Promos-40-Off-first-month/td-p/...
in the end, you save more than you think.
eddieO
@Jeannine_Ander1, you might already know this but in case you didn't, you can keep using the same SIM card even if you change plans or change phones but you can't transfer a SIM card to another account once it's already been linked to an account before, a SIM card can only ever work with one account and then it's done. I don't think you're going to have any luck trying to get the $15 plan back as it's no longer being offered but you can always try pleading your case to a CS agent.
You will need to open a ticket through the Chatbot:
(and then type: Customer Support Agent)
Or, if you are having trouble with the Chatbot try sending a private message to:
Chalupa_Batman
Hi @Jeannine_Ander1
There is no $15 plan currently.
https://www.publicmobile.ca/en/mb/plans?network=ALL
Cheapest is $19 but that's for new customers only.
EDIT: One a SIM card has been used, it's now garbage and you have to purchase a new one. If you still have a chance to get your account back, in other words it's been under 89 days, I'd suggest getting it back as I don't see those $15 plans coming back for a long time. If you're able to get your account back, you can still use that SIM card.
