yesterday
Just signed up with your eSIM. Messenger says I must put the phone number in Settings but when I try it won’t save it
yesterday
Try rebootin. If you have an iphone you will need to contact customer service agent to fix your issue. Either via the following link:
If you are having a difficult time, then you can private message CSA:
Send a private message to CSA through the following link :
yesterday
HI @Friesenator
but first check if your sim card is working. Voice calls work? text works? data works?
and by message, you meant iMessage? try to reboot the phone once more and enter the phone number again
