05-23-2024 06:17 PM - last edited on 05-23-2024 09:16 PM by computergeek541
I would like to transfer my koodo pay as you go plan to Public Mobile.
During the process Iam getting a pop up box stating Iam not a candidate to transfer my number to P. Mobile.
Can you please walk me through the steps to get started with P. Mobile service? Do I need to cancel with koodo, or just choose the option to not transfer the number but just pick another one?
05-23-2024 07:11 PM
Opening the correct ticket is even easier now. After you get the temp number, go to Account in the app and select Transfer phone number, there is a direct link there to create the appropriate ticket for porting of Koodo and PC Mobile numbers.
05-23-2024 06:21 PM - edited 05-23-2024 06:21 PM
If you are porting in from Koodo prepaid, you have to activate with a new number first. Once activation completed and you can make calls and recieve calls, then you will need to open ticket with PM support for a manual porting request.
When the new line is setup and you are ready to open ticket, here you are
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
