i want to transfer a koodo prepaid to public mobile please help
samuel1212
2 REPLIES 2
You'll need to contact a Public Mobile customer support agent.  Please do that be opening a ticket using the chatbot. https://widget.telus.tiia.ai/publicmobile/publicmobile.html
hi @samuel1212
to transfer from Koodo Prepaid, you have to activate a line with PM with a new number first
once the line is activated, you can then open ticket with PM support and they will need to be involved for the transfer
When the new PM account is created and working, please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
