03-27-2023 11:37 AM
03-27-2023 11:40 AM
There are some issues with 611.
Try calling 1-855-478-2542 or log in to your account and pay manually using voucher or registered credit card.
03-27-2023 11:39 AM
HI @DragonJane Please try calling 1-855-4PUBLIC for now as *611 has problem since last week
or can you login to My Account?
03-27-2023 11:38 AM
there has been some problem with *611 at the moment
https://productioncommunity.publicmobile.ca/t5/Announcements/Ongoing-Issue-611/td-p/963252
Try calling 1.855.4PUBLIC from another phone and enter your phone number. This is the same as using *611, you can top up your voucher there
Or you can also login to Self Serve My Account and load the voucher that way
03-27-2023 11:38 AM
Try calling 1 855 4PUBLIC and entering your 10 digit phone number.
