4 weeks ago
- last edited
2 weeks ago
Dunkman
Ok, l just notice a bill for a top-up that l never ordered. How do l get this reversed? l don't have a need for a top up as l have never even come close to using my 50 gb of data.
4 weeks ago
All is good. My credit card statement stated, "Top Up" and l was confused because l never asked for a top up. What actually happened is l applied my credits against my next bill payment and that was where the confusion was. They should have called it "Credit something" so there wouldn't have been any confusion.
4 weeks ago - last edited 4 weeks ago
@JoeS17 wrote:Ok, l just notice a bill for a top-up that l never ordered. How do l get this reversed? l don't have a need for a top up as l have never even come close to using my 50 gb of data.
@JoeS17 As you haven't returned, I suspect you were unaware that Public Mobile is a pre paid service provider. You bought a plan, paid for 30 days service with an allotment of 50GB. After 30 days your account renews automatically because when you subscribed to the service auto pay was activated by default. Doesn't matter how much of the 50GB you have remaining from the last 30 day period, it gets wiped and you start the next 30 day period with a fresh 50GB allocation. If you don't like auto renew, go into your account and turn it off. Be aware though that if you don't go and add funds every 30 days your service will stop until such time as you do add funds.
Edit: I see you have been with PM since 2024 so I must be completely off the mark with what the issue is. I'll go back to my last question, "what do you mean by top up"?
4 weeks ago
Is your renewal date coming up within a day?
If so, the top-up is for your next month renewal on AutoPay.
4 weeks ago
4 weeks ago
yes, you can open ticket with PM and ask them to check and issue credit
Simply open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.) When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble using Chatbot to open ticket, then message PM using this link:
PM will reply to your community inbox, between 9AM-10PM EST (Mon-Sun), check here:
4 weeks ago
Hello @JoeS17
You need to create a ticket to a CS Agent to assist.
If you are able to log in, please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket. Enter CONTACT US into the chat and follow the prompts.
If you’re unable to log in to your account, please use this direct link to reach out to a CS Agent.
