12-20-2023
09:18 AM
12-20-2023
08:14 PM
computergeek541
Good morning!
My rewards are more than my monthly bill and I am on the old system, not points. I am getting credit every month and don't have any way of using those funds. What are my options?
Thank you 😁
01-05-2024 05:39 PM - edited 01-05-2024 05:39 PM
@DDM69 no, funds on Available Finds won't get credited back to credit card or cannot transfer to another account, either. And you are right, can't be used for purchase phone
you can only use the funds for plan or add-ons
Only way to use it elsewhere now is to buy sim card:(
12-20-2023 04:02 PM
@DDM69 Out of curiosity, what is your current monthly reward amount?
12-20-2023 12:37 PM
HI @DDM69
I am jealous 🙂
No, the money can only be used for plans and addons , now it can be used to buy sim card too
other than that, you can't really use it elsewhere. But the extra will stay in your account's Available Funds. But save it and if any of your friends left PM and you are earning less, those extra you have now would help
12-20-2023 12:33 PM
keep reference people to PM ,until your credit enough to own PM😂
12-20-2023 10:20 AM
Keep this credit, base on this new garbage PM system, soon or later more and more those referrals will leave PM, you will getting less and less Rewards... Like me, I am shy to reference people to PM already.
12-20-2023 09:28 AM
Yep, realized and fixed it thanks.
12-20-2023 09:27 AM - edited 12-20-2023 09:31 AM
@TheSterlinger He’s in the old legacy $ rewards not the new point system
12-20-2023 09:26 AM - edited 12-20-2023 09:27 AM
Switching to a more expensive plan or buying add-ons should work.
12-20-2023 09:24 AM
@DDM69 Switch to a higher priced plan be one way to use them up . Or just let it continue to build up for future payments should some of those referrals leave PM
