2 hours ago
Dear Sirs,
Could you please help me to get my phone usage history from June 3, 2024 to June 4, 2024 including.
Thank you very much for your help.
Yury
2 hours ago
@Yury2 Unfortunately I think you can only go back 90 days in your account usage history . To go further back then that you only option would be to see if support can help even then I’m not sure they can but it’s worth a try
