Data Usage time
Mike0008
I am a new subscriber of PM and noted that most of my data usages were shown at mid night when I did not use the network service. Please advise if there is a delay in charging data usage on the Usage History list.
Thanks
1 REPLY 1
yes @Mike0008,  you are correct, there is a delay in updating data usage
PM does not update the data usage constantly.  In fact, it only update it twice a day.
So, any entry you see is just a total usage between that timestamp and the timestamp of the previous entry.  The early morning usage  you see on the Usage log does not mean it was used in the morning but a total usage for the last 12 hours.
Also, for correct usage reading, always use Incognito mode to login My Account to avoid reading cached old info
