02-03-2020 08:41 PM - edited 01-05-2022 10:32 AM
Outgoing calls are working but not incoming calls or text messages...How long does the porting process take to resolve this?
02-03-2020 09:02 PM
@rob_hfx wrote:I am porting from Petrocan mobility. I will give it a day and see what happens
Read my post how I port my Speakout number (same as PetroCanada Mobile) to PM in 4 hours without moderator assistant.
Create a moderator support ticket to supply the info required by PetroCanada Mobile using the ? button at the right side bottom corner of this page.
1. Tell SIMon what is the issue
2. Ask for "moderator"
3. SIMon will give your 2 choices. Click on the "Account-specific question"
4. Then, click on "No, I want a human"
5. Click "Submit a ticket"
6. Follow instruction to create support ticket.
Good luck.
02-03-2020 08:57 PM - edited 02-03-2020 08:59 PM
Hmmm, others may know something about that. I seem to recall hearing that providers/resellers such as PC Mobile can take longer to port away from so I bet that Petro Can would likely be in that group as well.
AE_Collector
02-03-2020 08:56 PM
Did you give your Petro Canada PIN code? They need that. If not open a ticket for moderators
02-03-2020 08:54 PM
02-03-2020 08:50 PM
@rob_hfx wrote:Outgoing calls are working but not incoming calls or text messages...How long does the porting process take to resolve this?
@rob_hfx The best way to determine when a port is 100% complete is to continue to use your old sim until it stops working. Once that happens you can start using the PM sim for both incoming and outgoing calls.
02-03-2020 08:50 PM
My experience porting from TELUS to PM was that it took at least 30 seconds....maybe as long as 45 seconds to complete!
AE_Collector
02-03-2020 08:48 PM
just checked my email, one from public says it can take up to 2 hours.
02-03-2020 08:48 PM
Yes porting from Koodo PREPAID accounts requires help from the moderators to complete. The most important piece of info if we are to give you any sort of accurate info is who you ported from, what type of account if it's as from Koodo and how long you've been waiting for it to complete now.
AE_Collector
02-03-2020 08:44 PM
i had to call a phone number because mine was Koodo, once they said done it was immediate.
02-03-2020 08:44 PM - edited 02-03-2020 08:45 PM
Anywhere from a few minutes to 24 hours.. landlines up could be a few days to 2week.
Who did you port from?
Put old sim back in and call your number from another phone does it ring still?
Texts will work if the people are on Telus Koodo or Public but not from other carries until port is complete.
Once completed you'll get a text from Public Mobile.
