Time of Call Shows Incorrectly in Usage History
Hollinger
For example, a call I made at 09:00 am PST shows as 06:00 am.
maximum_gato
@Hollinger
It started at the overhaul.....calls used to be in local time and text messages in eastern time. Now messages are in local time and calls are 3 hours (for me in bc) behind..... .....Hawaiian/Aleutian time. Hot and cold....that's how it goes at public mobile?!!
Hollinger
9am PST shows as 6am.
Rarely check my usage history so don't know when it started.
In the past, a  9am PST call would show as 12pm EST
@hTideGnow- Are you outside eastern time? If so, try it. Yes, it's reversed. It used to make some sense with some of the timestamps being eastern time.
HI @Hollinger
since this My Account upgrade? or it just start showing wrong time today?
If you meant 6am PST call showing as 9am, it makes sense, but the other way around. 🤔
dust2dust
Yup. Yet another bug. Just more evidence of lack of testing.
