Time not accurate in NL.
dnewf
Seems like my time on my samsung 6 is off by 3 minutes earlier. My friends have bell and telus theres are fine. I dunno if it can be fixed or not?
7 REPLIES 7
Korth
It seems a little strange to me.
My understanding is that the whole cellular signal multiplexing system is based on timing.  Computer-precise timing.  All devices on the network automatically time sync because it's the only way to even make it work.
But that being said ... hundreds of different devices running thousands of operating system revisions across tens of thousands of towers for tens of millions of users ... law of large numbers, no strange anomalies at all would be the strangest anomaly of all.
dnewf
set manual then went to auto.
mimmo
@dnewfwrote:
Thanks worked perfect!!!!
Which of the above?
dnewf
mimmo
@dnewf assuming that you have not set time manually.
you could also try setting manually then retuning to automatic time.
dnewf
Do I reply directly to them with the problem?
will13am
It might not hurt to ask the moderator team about this.  @CS_Agent, please weigh in on the time discrepancy issue in NL.
