Can't send sms
01-17-2025 11:52 AM
I sent many sms in a short period of time now It doesn't work when I send some
Service
01-17-2025 03:27 PM
you sure the old provider's sim card is removed or alll old eSIM disabled?
try Reset Network Settings. Next is to ask PM to help, they can reset the account on the system . Not sure id you can properly login to open the preferred Chatbot ticket, you might want to message them here
01-17-2025 03:23 PM
I have cleared cache and data on my messaging.All my web browsir's gun restarts even removed and reinstalled my sim card. It'll send one text message and then not the other.I am able to receive phone calls.... Super frustrating.. We have been with public mobile for 10 years.I'm thinking about switching w t f
01-17-2025 12:18 PM
01-17-2025 12:09 PM
Mine is the working either.payment ok turned airplane on/off and restarted ..frustrating
01-17-2025 12:05 PM
If you've tried airplane mode on and off, restarting phone and it still doesn't work, you can try resetting networks. Should these not work either, ask PM to check your account. You can use the chatbot or link below.
01-17-2025 12:01 PM
Yes and yes
01-17-2025 11:58 AM
@Nickmane so you cannot send text messages. Are you able to receive them? Are calls being received?
