Ticket
Jaywalia_100229
How to raise a ticket or talk to customer care..?
slusagm
@Jaywalia_100229
what question you have?  maybe we have the answer and you don't need to raise a ticket
But to  open ticket with PM , click the Orange Chatbot icon on the lower right. (For 2FA  code when login, use email to receive code instead of SMS if you cannot receive the text on the phone.)    When open Chatbot ticket, Type the question Submit ticket and select Contact Us to get to ticket open screen
Or you can also message PM using this link:
PM will reply to your community inbox,  between 9AM-10PM EST (Mon-Sun), check here:
Chalupa_Batman
What issues are you having? Maybe we might be able to suggest a fix that may be faster than a CS Agent.
hairbag1
@Jaywalia_100229
let us know what the prob is and we can give you better direction. If you haven't created an account yet, you'll have to use this link to message Customer Support...
If you do have a Public Mobile account, use the direction provided by @TheSterlinger .
TheSterlinger
What did you need help with? Maybe someone here can help??
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
'Contact Us', and choose your topic.
