04-20-2024 11:14 AM - edited 04-20-2024 11:23 AM
What is causing this, i had it fixed once by messaging a mod, it worked once since then stopped working again today. This is unprofessional and i need a phone plan that does its job.
When i do the three way call i can hear the 3rd person i call and the second person can hear the third person but i cannot hear the second person.
Is there a way to reliably fix this for more than one use or is PM unable to provide working service?
Oh and my last profile seems to have vanished, this is my 3rd of 4th community profile, though thats small potatoes 🙄
04-20-2024 11:27 AM
Thanks, i submitted a ticket though it had no option to explain what the issue is, just that its a talk/text issue.
Public Mobile is really falling apart.
Funny how i used to consider it a good service provider, this is getting into Freedom Mobile territory
04-20-2024 11:23 AM
@G6q - I dunno. PM is currently having a half dozen little eggs cracking (Issues) like Call forwarding which already cracked, conference calling which you reported on, payments which is cracking, iMessage activation which is cracked, and SMS & MMS not working which is cracked.
But maybe message CS_Agent and see if they need to do anything on their end.
⬇️ Click the link for an Agent * ⬇️
If the link above doesn’t work correctly, please go here to create a ticket to CS_Agent: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
* - CS_Agent will typically get back to you within 48 hours. * CS_Agents are at load due to iMessage activation issues so it may take longer than 48 hours. * They work 7 days a week from 9 AM to 10 PM EST. You will be required to login to your Public Mobile Community Account to contact CS_Agent. Once you are finished making the ticket with CS_Agent, please ensure that you monitor for one of the agents responding back to you because they may notify you asking for some information via Private Message, in your mailbox by clicking this link here: Messages
