11-03-2023
09:39 AM
11-03-2023
05:02 PM
computergeek541
I use iphone 14 pro and when i am trying to transfer to esim they are saying my phone in incompatible. What should i do
11-13-2023 05:30 PM
HI @Nazifa2
great. keep checking the community inbox for PM agent's reply. let us know how it turns out
11-13-2023 05:29 PM
I did as u instructed
11-13-2023 05:26 PM
Did you use the app on the 14 and buy and install the esim? Did you get a physical sim card as well? You can log in to your account to change sim to the physical card if that's what you need to do. But only a new never used card.
11-13-2023 05:26 PM
HI @Nazifa2
SOS error. I think just a eSIM setup problem on the system
Please submit ticket with CS agent and they can fix it quickly
11-13-2023 05:23 PM
I did but it doesnt work
11-13-2023 05:14 PM
HI @Nazifa2
you just need to reboot your phone once
and on that screen you see, network selection, choose Public Mobile
11-13-2023 05:12 PM
And this is the iphone 14 pro
11-13-2023 05:11 PM
This is the ss of my iphone 12 mini
11-13-2023 05:11 PM
11-13-2023 04:47 PM
When i transferred from physical sim to esim, the previous sim stopped working. How do i get the physical sim with the same number again
11-13-2023 04:45 PM
Hi so can u imagine even after a month your public mobile cannot fix my issue. I am getting very frustrated. I went to the telus kiosk today and they said there is nth they can do. It is still saying incompatible. All they did is provide me a free sim card but that is not even working. Please for gods sake fix ur error.
11-13-2023 03:04 PM
I tried everything but doesnt work
11-13-2023 03:03 PM
I cannot see anything
11-03-2023 11:52 AM
11-03-2023 09:54 AM
what exact error you got , the incompatible error?
Try to uninstall the PM app on your new phone first, then clear cache on the default browser on the phone. Try reinstall PM app and try buying again
if issue presists, please open ticket with support
11-03-2023 09:53 AM
i tried buying it for the new phone but it doesnt work
11-03-2023 09:47 AM - edited 11-03-2023 09:47 AM
you have the eSIM on your iPhone 12 and you try to "transfer" it to the new phone?
For eSIM with new phone, you have to re-buy a new one for $5.
Yes, while eSIM is "cool", there are disadvantages as well. For eSIM, if you have a new phone, or if you ever wipe your phone, you will have to re-buy a new eSIM again. There is no such problem with Physical sim card.
To rebuy new eSIM, First, download the app on your new phone (the iPhone 14), click ⊕ or ⧁ at the bottom left to bring up the menu and go to Subscription & Add-on page, scroll down to the bottom and click Shop SIM Card Now. You can buy and install eSIM from there
11-03-2023 09:45 AM
I had the esim in my previous iphone 12 mini but now i am trying to change it to my iphone 14 but its not working
11-03-2023 09:41 AM
iPhone 14 certainly is compatible, sometimes, it is a false negative.
Let's try to confirm the eSIM or try install the eSIM again. Did you get to the eSIM installation step? Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email. Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone , disable those non PM sim (eSIM/Physica sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetoosh connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
