01-10-2023 12:57 PM
01-10-2023 02:31 PM
@Lightbulbs are you trying to replace sim card from My Account to your existing account? If you are , there is a glitch with Change Sim card using Mobile phone. Please try it again using a desktop or laptop computer
if you are activating new account, make sure the Public Mobile sim card is brand new, never used before
01-10-2023 02:26 PM
Then contact the CSA's to inquire about the SIM card.
It certainly shouldn't be this onerous to activate a SIM card.
01-10-2023 01:56 PM
yes, 8912230........
also the number on the SIM card matches the number on the bar code of it's packaging.
I put it in the phone and it shows blank details.
01-10-2023 01:40 PM
And those first digits? And it's a new (to you) sim? You can insert the sim to see if it has any previous details to see if it's a used sim or even from Public.
01-10-2023 01:36 PM
Getting activated for 1st time. Went to public mobile activation page and 1st step is putting in the new SIM card number. Once all correct 19 digit added to page boxes, the RED error "Please enter a valid SIM number".
Sim card has not gone into phone until activation is done......
01-10-2023 01:16 PM
Contact a Customer Support Agent about the Sim card.
Use the Chat Bot Simon to get a service ticket started.
Or send a private message to CS_Agent
01-10-2023 01:16 PM
What happens when you insert the sim? How old is the sim? Do you have active service here? Are you doing the change sim or are you activating a new account? Are the first bunch of numbers 8912230....?
01-10-2023 01:14 PM - edited 01-10-2023 01:16 PM
You can ask the customer support agents if it's a valid and usable SIM number.
However by "resettable" if you may be implying it may have been used before, then in that case it is not usable now.
01-10-2023 01:10 PM
is there someone who can check if number is useable or resettable ?
01-10-2023 01:08 PM
tried using google - still problem
tried using edge - still problem
tried incognito mode - still problem
tried clearing cache above - still problem
using 2 different laptops, windows 10 on one and windows 11 on other - still problem
01-10-2023 01:05 PM
01-10-2023 01:04 PM
Did you receive the Public Mobile SIM card on this site (via mail) or at a Telus, Koodo or Mobile Klinic location?
Just to be certain, this is a brand new Public Mobile SIM card, correct?
If it is in any way questionable whether it has been used previously, they can only be activated if they've never been previously attached to a service.
Try using the number on the SIM card packaging itself as opposed to the number on the small Sim card. It may be easier to read on the packaging.
01-10-2023 01:00 PM
@Lightbulbs @Try again incognito mode / private mode there are cache issues
01-10-2023 12:59 PM
Try Incognito/private mode. Clear browser’s cache. Try forced refresh. Use computer and not phone to log in.
01-10-2023 12:58 PM
Try logging in using a browser in incognito or private mode instead
Use a computer or laptop instead of your mobile phone.
