10-31-2022 09:38 PM
That was available yesterday - How can I activate it now?
10-31-2022 09:58 PM
Thank you Yummy - Your feedback has been appreciated!
A number of fellows stepped in immediately to reply to my question, and I had to accept the first one.
10-31-2022 09:56 PM
Thank you kindly for your answer - Much appreciated!
10-31-2022 09:55 PM
Thank you kindly for your feedback - Much appreciated!
10-31-2022 09:51 PM
Just checked - plan is still here.
You have to log in and initiate plan change. Then 15GB plan will appear on your list. It does Not appear on a list of regular PM accounts. Go and try it...
10-31-2022 09:43 PM
@abstergio Just checked, still available. Use incognito/private mode to login and select the 4G tab and then use the arrow to the right side of plans to scroll to the second $40/15GB plan as there are two same priced plans.
10-31-2022 09:42 PM - edited 10-31-2022 09:43 PM
@abstergio The plan is still there.
Use Incognito Mode to login (or use another browser) . When you are at My Account, change plan, make sure you click 4G plan and the $40 plan will be the 2nd one there (it lists both OLD $40 plan and the new one, the new one is the 2nd one)
