08-23-2020 05:22 PM - edited 01-05-2022 03:38 PM
Hi there,
I switched over to Public Mobile from Koodo just last month and ported my number to do so. Occasionally when I send texts, they send from the temporary number which I was given in order to keep my original phone number. It only does this with certain numbers and at random times. Can somebody help me fix this?
Thank you!
Service
08-23-2020 05:33 PM
@Inexot seems that your account wasn't provisioned properly. Contact the moderators and ask them to reset your service.
There are 2 ways to contact the Moderator Team:
- Faster response- Get help with your account the easy way by starting a conversation with our virtual assistant, SIMon. It’ll take you to relevant help articles, or if it’s something more urgent, it can help you submit a ticket to the Moderator Team. Click here to get started.
- Slower- Alternatively, you can send a private message to the Moderators by clicking here. You’ll need to be logged in to your Community account for the link to work.
Once connected to Simon, you will be asked to log in again with your community user name and password. Please do, this allows you to continue and send your message.
- Keep an eye on the envelope top right of your screen. The mods answer will show up there. When it does, you will be asked to verify your self service account, with your password and login. Doing so allows the process to continue. Stay safe.
08-23-2020 05:32 PM - edited 08-23-2020 05:36 PM
@Inex wrote:Hi there,
Thank you!
@Inex hi sounds like an issue with your account try contacting a moderator you can do so by clicking the question mark at the lower right corner,to avoid going around in circles with Simon say that you want a human to speak to, a ticket will then be generated briefly mention your issue, you should get a response between 2 to 48 hours a reply should show up in your little envelope in the top right corner
08-23-2020 05:31 PM
Thank you!
By any chance are you using iMessage? Is it possible that iMesssage may still be associated with the other phone number. I'm not too familar with Apple software, but my thinking is how messages to non iMessages users would be sent by standard SMS, for which the information about the sendeer would be set by Public Mobile. As for messages to other iMessages users, it could show an incorrectly associated phone number if the message gets sent thorugh the internet, but the correct number if it ends up gettting sent as SMS.
08-23-2020 05:30 PM - edited 08-23-2020 05:30 PM
@Inex If your phone port completed normally and you can receive calls from customers that are non Telus, Koodo or Public then go into your messages app and clear the cache and restart your phone.
If it's still a problem hit the ? and submit a ticket to PM for help.
08-23-2020 05:30 PM
Which model phone do you have?
Does talk outgoing and incoming work fine?
Maybe try rebooting your phone. Network reset of the phone.
