Texts only arrive with wifi
kenholman
Unable to receive texts away from a wifi connection. Have minimal plan which I thought includes "unlimited" texts. Can anyone suggest why texts are not appearing 'in the field' and only appear when arriving home and connecting to wifi?
Thanks
self solution removed
Ooops, if that ends up being the case you may way to give @softech the solution for your issue.
kenholman
That may be the answer. Need to get away from home wifi to test. Thank you!
@kenholman   Sound like you are using iMessage or RCS instead of native SMS.
What is the could of the text you got?  these is how to distinguish them:
You can turn off iMessage or RCS if you don't meant to send using them
To turn off iMessage on iPhone
On your iPhone, go to Settings.
Tap Messages.
Toggle off iMessage.
To turn off RCS on Android
Open Messages by Google. Ensure you are on the page that lists different message threads with different contacts.
Tap the three dots in the top right corner.
Tap Settings.
Tap Chat features.
Toggle off Enable chat features.
JK8
@kenholman
Are all your other services working? Have you tried rebooting, resetting network settings, reinstalling SIM card, clearing texting cache, trying SIM card in another unlocked phone.
