Texting
Buck22
Hi
I have Canada/USA plan
Not able to send anything except text no picture not even a 800kb picture what wrong
Thanks for helping me
2 REPLIES 2
Chalupa_Batman
@Buck22 wrote:
Hi
Hello @Buck22
To confirm, do your other options work? You can call and accept calls? Data works? There was an update on both Android and iPhones in the last few days, that may have changed a setting or two as it did mine.
You can try going into Network Settings and turn off Automatic and pick T-Mobile as that seems to work best. Then reboot and try sending a text/picture again.
HI @Buck22
you are sending MMS and you need Mobile data to turn on .  Please confirm if it is on
if already on and unable to send, try reboot and Reset Network settings
if still unable to send , come back and let us know what model of phone you have
