12-07-2024 02:58 PM
since switching to public mobile i cannot send pictures or voice notes, can someone help?
12-14-2024 07:49 PM
I had the same issue with group messaging. I had to change a couple of settings for the APN on the network.
12-07-2024 04:43 PM
You will need to contact a CS_Agent to investigate your issue:
12-07-2024 03:52 PM
tried that but doesn't seem to work
12-07-2024 03:41 PM
yes the data is enabled and have rebooted many times as well
12-07-2024 03:31 PM
android, other services seem to work except for group messaging actually doesn't either
12-07-2024 03:18 PM
Is the Cellular data enabled because you need data for the MMS to be sent to others.
Also try rebooting your phone by powering off then back on.
12-07-2024 03:06 PM
@Mary226, are you using iPhone or Android? Are all other services working as expected?
12-07-2024 03:05 PM
@Mary226 wrote:since switching to public mobile i cannot send pictures or voice notes, can someone help?
Hey @Mary226
My buddy experienced this when he ported over. The way I helped him fix it was to go into his network settings and reset them. Then I went into his network settings and turned off automatic and picked Public Mobile and rebooted. That worked for him.
