Texting while in the USA
crookedlake
Hi,
Just new to public mobile so want to make sure when I do the Add On for texting while in the USA that I have it right without any surprises on my bill when I return.   I leave on May 3 and return May 17 so my question is - The texting add on is only for 10 days for 8$ or can you add extra days to cover the 14 days.  I assume its unlimited texting and that I can text to friends that are visiting the US with Canadian phone numbers.  As well, I am able to text back to Canada with this coverage.
Please advise!
2 REPLIES 2
hairbag1
You can text whomever you like for 10 days. After 10 days you'll have to get a new US Roaming Add-on.
NDesai
@crookedlake The US roaming add-ons will only cover 10 days. You will need to buy another after one ends to extend for more days. You will be able to text to US and to Canada while in USA. Your friend in USA will only get texts if they are covered for receiving/sending texts from their carrier.
