Texting trouble
KwH
When I try to send a photo in text or sometimes just a text I get the message “mms  messaging needs to be enabled to send this messsge” but my mms messaging is turned on.
10 REPLIES 10
KwH
I fixed it! I had to reset network settings under general settings on my iPhone.
[ .......... Luddite]
@KwH
No it shouldn’t matter.
KwH
I have an old SIM card still in the phone and a new esim. Could that be the problem?
@KwH
If you have an iPhone, go to Settings>Messages>scroll down to MMS Messaging and see if it is enabled. Same with Send as SMS and enable.
Meow
DATA has to be enabled in order to send/receive MMS but sending/receiving MMS will NOT use your data allowance.
You need to enable Data in order to take advantage of MMS type messages.
HI @KwH
are you using esim or mutliple sim card on iPhone?
you simply just need to enable mobile data
KwH
Cellular data is listed as secondary
hi @KwH
as it said, you were sending MMS.  To send MMS, mobile data needs to be enabled.  But no worries, it does not really use your data, just need it turned on for some technical reason
hairbag1
@KwH
is Data enabled in settings ? If not...enable it.
