Texting issues
nicomy20
I can't sending any text local or int?
popping
If you are using iPhone, you need to configure iMessage to send text using the cellphone text channel instead of using iMessage protocol over wifi or mobile data.
DanLem
What type of phone do you have?
ShawnC13
Are you connected to the network?  Are they a SMS or MMS you are trying to send?  Have you restarted your phone?
