a month ago - last edited a month ago by computergeek541
I'm able to login in the web browser, but not in the mobile app
a month ago
hi @AlexeiCA yes, you need support to help to complete the activation. Provided the way to message them above
@AlexeiCA Ok in that case you do need the app to activate . Can you use a friends phone to download the app to activate the SIM card ? Then just delete the app from their phone and you can use website to manage the account after that . Or if you have already paid for the subscription on website you can contact support to finish off for you
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
a month ago
I have a physical sim that I'm trying to complete the activation process and it keeps taking me to the app to complete the activation
a month ago
@AlexeiCA What are you trying to do with your account ? Most things can be done on the website for account changes besides re buying eSIM .
a month ago
hi @AlexeiCA try again on another phone if possible
at the same time, ask support for help, you can submit by direct message:
a month ago
Tried that too. It keeps return to the main login screen
a month ago
hi @AlexeiCA after updating the apps, clear browser cache as well as the app calls the browser to authenticate and it could be a browser cache problem
a month ago
@AlexeiCA Yes they just updated the app 24 hours ago
a month ago
Tried that already. No luck. I can Try again. It is brand new
@AlexeiCA Try clearing PM app cache or uninstall the app and reinstall it and try again
add and be sure to update the app too if needed
