02-19-2021 09:04 PM - edited 01-05-2022 05:21 PM
Are SMS &/or texting one in the same, what's the difference?
02-19-2021 10:10 PM - edited 02-19-2021 10:29 PM
SMS = "Text" (up to 160 characters of plaintext ASCII, longer messages are segmented)
MMS = "Picture Messaging" (SMS with file attachment)
MMS protocol allows any sort of file or files to be attached. But in practice, the software built into most phones will only really work with common photo formats, sometimes also common audio formats. Other (better) softwares can always be installed, but many people don't bother.
All current Public Mobile plans have "Unlimited International Text" with "Unlimited International Picture Messaging". You could send or receive as many texts as you like (with or without attached images) to or from anywhere in the world for free as long as your phone is in Canada with an active plan (or is in USA with an active US Roaming add-on).
MMS requires active cellular data. And Public Mobile's APN settings.
Each MMS is logged in Self-Serve usage history as an "MMS Event" which consumes 0.00MB of your data provision. (This data usage is essentially paid for by Public Mobile, not by the subscriber.)
If data isn't active then you'll just see a "click to retry/upload/download" placeholder instead of a picture. The network usually stores undelivered messages/attachments for a while.
Some people have reported difficulties with Texting to/from phones in countries which aren't part of Public Mobile's "International" list. It doesn't seem to be a problem for most people.
Some legacy plans had a variety of different (but typically more limited) Text provisions and conditions. But legacy plans aren't available for new number ports or activations.
02-19-2021 09:12 PM
Hi @jojo9 ,
Texting is either SMS or MMS.
SMS=stands for Short Message Service
MMS=stands for Multimedia Messaging Service. It’s most popularly used to send pictures, but can also be used to send audio, phone contacts, and video files.
Then there is iMessaging that can be done through wifi.
02-19-2021 09:07 PM - edited 02-19-2021 09:12 PM
Yes, they are the same...
SMS is the more formal name , Short Message Service
