Test message to locate the "Draft" Functionality!
shyama24x7
I am trying to find where the message is kept as 'draft'. Not sure if I will find it or not - but am going to give it a try!
CountyDownIeUk
Are you talking about a draft email or a draft text message??
And on what device and what app?
@shyama24x7
Just open the text who you are going to send it to.
solitude
If it doesnt show in the list with all the other text messages on your phone.  It' gone.
@shyama24x7
Text message draft?  if you are talking about phone, it should be just with other text
dabr
@shyama24x7   Click your avatar top right and select My Profile and then scroll down, the drafts are on the bottom right below the bravos summary.
edit:  upon second read, are you talking about draft text messages on your phone?
