03-29-2024 07:23 PM
07-21-2024 09:43 PM
I know this is an older thread, but thought I'd chime in if others find it. I have had trouble with LTE where I am at my cottage which is a bit off the beaten path but not overly - still within range of cell towers. I am new to Public. I was with Koodo so I figured Public would work just as well here - it hasnt so far. But I turned off 5G and LTE and am now getting consistent connections, whereas before it was on and off.
03-29-2024 07:53 PM
I'm on the $34 5G plan.
iPhone XR get's 103 Mbps down and 25 Mbps up
iPhone SE 2020 gets 121 Mbps down and 20.5 up.
03-29-2024 07:26 PM
HI @Corynick
you turned of LTE and become 4G, but 4G is LTE!!!
what other option you have in the network mode? did you try automatic? 5G? or even 3G? try them all
but before you try them all again, try Reset All networks first, then test your different network in different area, not just one
and what phone do you have?
Better to test the sim in another phone too
