Terrible reception
79Bandit
Everyone keeps telling me they can’t hear me and that my phone keeps cutting out. I can hear them okay though .
8 REPLIES 8
hi @79Bandit
iPhone should work well.  Make sure OS is up-to-date, Carrier Profile is update.  Reboot phone and click Reset network settings
try changing the network mode.  Test each: 4G/LTE or 5G on and 5G auto
79Bandit
between one and two. LTE.
Dunkman
@79Bandit
Have you tried the phone in different areas around your city or town?
Check the follow cell tower map to see where is the nearest Telus/Bell cell tower.  You might be in an area with poor coverage.
https://www.scadacore.com/tools/rf-path/cell-tower-map-canada/
FRoStYisGoD
how many bars of signal do you have? If only PM had Wifi calling
79Bandit
I have the iPhone 13 and I did check if I have VOLte and I do. I also have 5 g
79Bandit
I have an iPhone 13 and have never had a problem like this with Rogers. I will try what you suggested and hope for the best!
@79Bandit
what phone do you have?  did you try Reset Network Settings after a device reboot
also, confirm if your phone has VoLTE and if it is compatible with PM network using the IMEI checker here:
https://www.publicmobile.ca/en/get-help/articles/volte
