Telus network down in MTL area
Jb456
Hey PM when will the network be fixed? Been all morning on PM and Koodo. Thankfully my business line is on Roger’s and their network is working. Please fix asap
7 REPLIES 7
 HI @Jb456
is your service back and running again? The outage is now resolved
@Jb456
do you still have problem in DT Montreal?
Phil_Adelphus
There's an outage now being reported in the Chateauguay area, not exactly Montreal but you can report an outage via the same page  https://www.telus.com/en/outages
Meow
We know as much as you do since only PM customers lurk here 🙂
Check provided outage map but if outage is small it might not be there.
@hTideGnow  Yes. As well as my Koodo lines. All SOS.
@Jb456
You can also check on the outage map in your area:
https://istheservicedowncanada.com/status/telus/map
HI @Jb456
thanks for reporting.  There was another post earlier today confirming that
But Telus outage page still not showing the outage.  Hope it is because it is small outage only
you tried 3G or 4G or 5G ?
