T2A
05-17-2023
08:47 PM
05-17-2023
09:15 PM
computergeek541
I have this plan for a long-distance use only since I have another service to use for the other needs. It doesn't go through when I tried to call. Would you late my calls connected or do I have to cancel my plan with you guy? I don't know what to do since my calls can go through.
Thanks,
Plans
05-19-2023 03:53 PM
@Community_QA wrote:what is T2A ? is that Calgary area code?
There was a complete postal code in the title previously, but I removed it.
05-19-2023 03:50 PM
05-18-2023 09:43 AM
@Changmut - do incoming calls work? How about texting in/out?
Others members here can try and help, but more details would be helpful.
You said you only use for long distance. What plan are you on?
Are you receiving a message saying you 'do not have long distance' or 'you are out of minutes'?
05-17-2023
09:01 PM
05-17-2023
09:15 PM
computergeek541
05-17-2023
08:54 PM
05-17-2023
09:15 PM
computergeek541
Firstly, @Changmut , you're chatting with OTHER customers here so .... yeah.
Try rebooting your device, resetting network connections.
Check your account status - is it listed as ACTIVE?
Call 611, what messaging do you hear?
If you need Customer Support, here's how:
- Use the ticketing system for a faster response time. Click here to create a support ticket, then type Customer Support Agent, then Contact Us, or,
- Send a private message to Customer Support Agent by clicking here. You’ll need to be logged into your Community account for the link to work.
