HOW TO Enable MMS on Samsung
bobmady
I recently have experienced problems with sending andis  receiving pictures sent in messages. I get an error message that it cannot download. My mobile data is enabled. I have tried restart.  This is a new problem.
Community_QA
MMS is APN problem. Check that first
@bobmady - sometimes a restart of your phone can fix this,
Or there is a network issue in your area, but hopefully temporary. If you can try your SIM into another phone this would rule out (or in) a device issue,.
Hi @bobmady
enable Mobile data to send and receive MMS
if that does not work, you could try to Reset All networks
Yummy
I just looked at my S7 but did not see anything specific.
Data has to be ON in order to send/receive MMS. Using NATIVE - not third party texting app.
