Switching from $25 plan to $34/25GB Plan
ComicCuriosity
Hi, guys,
I’m currently on the $25 monthly plan but am considering switching to the promotional $34 25GB plan.
If I switch over, will I still keep my public rewards? I currently have $9 in monthly credits.
Also, can I switch back to the $25 plan at any time? I've been on the $25 monthly plan for over 4 years now.
Thanks!
17 REPLIES 17
@ComicCuriosity wrote:
Oh, that sucks! So that means I can't apply for the $34 plan?
Sorry, but no as the $35 25GB plan is only available to new customers.
@ComicCuriosity  Yes there will be warnings if your in your rewards portal about switching to points . Just stay away from there and no worries . And for changing your plan yes there’s a box to tap change on next renewal like this
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
ComicCuriosity
To switch your Rewards is all voluntary so DON’T switch. The old Rewards system is better since you will get a monthly credit and no more $2 for AutoPay.
How do I check that I don't switch my rewards? That's what I'm worried about.
yen
Thank you!
That clarifies my question 🙂
@yen  It is only $5 cap loyalty reward . But you see $15 in my screen shot because of a 90 day plan I’m on so I see the rewards x3
yen
Hi there!
I saw all the details and I found out you have a 15$ loyalty, how did you get that? is it 1 per year?
I was told not possible to get more than 5$ loyalty when I turned 7 years with PM.
Could you please tell me more about it?
@Carolccc "I think you can change your plan at any time if the plan is available."
Yes you can but if you change before the scheduled renewal date there is no prorating since PM is prepaid. So you would lose the rest of the current plan and no refund for the unused portion.  That's why change plan on renewal is usually the preferred option over change immediately.
Gwanzi
Thank you!
Carolccc
Carolccc
By the way, on Black Friday promotion plan $34/40gb, maybe Boxing Day have better plan than $34/25gb. Just guess.
Carolccc
I just change my $25 plan to $29, the rewards still there. If you didn’t change the reward to point, I think the reward are always there.
Not unless you start afresh with a new account and number, in which case you'll also need a new SIM card.
I'd recommend you wait for the Boxing Day sales - there are sure to be specials for both existing and new customers then.
@ComicCuriosity
I would suggest you wait until Boxing Day. There are normally promos like on Black Friday/Cyber Monday.
@ComicCuriosity  No you won’t lose your old rewards I can confirm this , I just switched to $34 plan too and kept my rewards have a look
HALIMACS
@ComicCuriosity
Switching plans advertises Public Points, however, users NEED NOT switch to Public Points to take advantage of plan changes.
Just make sure to never, ever, switch to Public Points.
You are wise to remain with the now Legacy rewards program - many who switched wish they hadn't.
ComicCuriosity
Changing plans doesn't change the rewards, but in any event, existing cusotmers unfortunately are ineligible for the $34 25GB plan.  it's for new customers only.
