05-28-2023
07:54 PM
05-29-2023
12:02 AM
Dunkman
Will Loyalty and subscription transfer to the new plan?
05-28-2023 07:56 PM
@BBry Changing plan won't change your rewards system. So, as rewards , you will get the same rewards. No worry, go ahead and make the change and enjoy the new plan. (make sure you use Change plan on renewal if you are in no rush of the data from the new plan)
05-28-2023 07:56 PM - edited 05-28-2023 07:56 PM
05-28-2023 07:55 PM
HI @BBry Yes. You will get to keep all the loyalty and other rewards.
05-28-2023 07:55 PM
@BBry Yes, all your rewards will stay as is when you switch plans.
